In the following code: ******************************************** #include <REG51.H> unsigned char rem(unsigned char d1,unsigned char d2) { B=d2; ACC=d1; #pragma asm DIV AB; #pragma endasm return B; } void main(void) { while(1) { unsigned char x,y,z; P0=255; x=65; y=10; z=rem(x,y); P0=z; } } ***************************************** I noticed that the instruction d1=ACC is not converted into assembly (Keil ignores this line). Is this any reason behind that?..How can I solve the problem? Thanks
Trying to utilize commonly used registers like ACC, R0-R7, B, DPTR, SP, etc. directly from C is not a good idea. You should learn the compiler's calling conventions and register usage, then expand the scope of your 'asm' pragmas and code anything that deals with registers in assembly.
I don't have my C51 toolchain ready at hand to check this, but something like:
unsigned char rem(unsigned char d1,unsigned char d2) { #pragma asm MOV B,R5 MOV A,R7 DIV AB MOV R7,B RET #pragma endasm }
Thanks, this solved it... By the way: Is there any easy way to get the remainder of unsigned division? Thanks again
