Hello, being new to this, i'm not totally sure I'm not doing something silly wrong. Below are two 'C' files, one which works in the target hardware and another which does not. I am using an Atmel AT89S8252. All code compiles fine and seems to run well on the simulator. The code just initialises an LCD, and writes some characters to it. The only difference between the two programs is that one puts the LCD initialisation in a function called from main()and the working one just does it all in main(). Why will this not work? Any help is welcomed. I use alot more function calls in my project, but am equally unable to get that work aswell. Code follows: Working code:
#include <AT898252.H> #include <stdio.h> void Delay(void); void Data_Write(void); void Initialise(void); sbit RS = P2^0; // sbit R_W = P2^1; // Set LCD controls sbit Enable = P2^2; // main() { TMOD=0x12; // Timer 1 is set for mode 1 operation P0=0x00; // Make P1 output for LCD data RS=0; // R_W=0; // RS, R/W, E = Outputs Enable=0; // Delay(); // 8 bit mode, 2 line, 5x8 character P0=0x38; Data_Write(); Delay(); // Display ON, Cursor OFF, Blink OFF P0=0x0C; Data_Write(); Delay(); // Clear display and return to home P0=0x01; Data_Write(); Delay(); // Increment at write and shift cursor to right P0=0x06; Data_Write(); Delay(); // Set position to line 1 pos 6 P0=0x86; Data_Write(); RS=1; Delay(); // Write H to LCD P0='H'; Data_Write(); Delay(); // Write M to LCD P0='M'; Data_Write(); Delay(); // Write E to LCD P0='E'; Data_Write(); Delay(); // Write ' ' to LCD P0=' '; Data_Write(); Delay(); // Write ' ' to LCD P0=' ' ; Data_Write(); Delay(); // Write M to LCD P0='M'; Data_Write(); Delay(); // Write k to LCD P0='k'; Data_Write(); Delay(); // Write 5 to LCD P0='5'; Data_Write(); while (1); // Stay here } void Delay(void) { int n; // Delay for 6.1ms with 24MHz clock TH0=0x00; TR0=1; for (n=0;n<50;n++) { while (!TF0); TF0=0; } TR0=0; } void Data_Write(void) { int x=4; // Write Data to LCD int y=20; while (x) x--; Enable=1; while (y) y--; Enable=0; }
#include <AT898252.H> #include <stdio.h> void Delay(void); void Data_Write(void); void Initialise(void); sbit RS = P2^0; // sbit R_W = P2^1; // Set LCD controls sbit Enable = P2^2; // main() { TMOD=0x12; // Timer 1 is set for mode 1 operation P0=0x00; // Make P1 output for LCD data RS=0; // R_W=0; // RS, R/W, E = Outputs Enable=0; // Initialise(); while (1); } void Initialise(void) { Delay(); // 8 bit mode, 2 line, 5x8 character P0=0x38; Data_Write(); Delay(); // Display ON, Cursor OFF, Blink OFF P0=0x0C; Data_Write(); Delay(); // Clear display and return to home P0=0x01; Data_Write(); Delay(); // Increment at write and shift cursor to right P0=0x06; Data_Write(); Delay(); // Set position to line 1 pos 6 P0=0x86; Data_Write(); RS=1; Delay(); // Write H to LCD P0='H'; Data_Write(); Delay(); // Write M to LCD P0='M'; Data_Write(); Delay(); // Write E to LCD P0='E'; Data_Write(); Delay(); // Write ' ' to LCD P0=' '; Data_Write(); Delay(); // Write ' ' to LCD P0=' ' ; Data_Write(); Delay(); // Write M to LCD P0='M'; Data_Write(); Delay(); // Write k to LCD P0='k'; Data_Write(); Delay(); // Write 5 to LCD P0='5'; Data_Write(); } void Delay(void) { int n; // Delay for 6.1ms with 24MHz clock TH0=0x00; TR0=1; for (n=0;n<50;n++) { while (!TF0); TF0=0; } TR0=0; } void Data_Write(void) { int x=4; // Write Data to LCD int y=20; while (x) x--; Enable=1; while (y) y--; Enable=0; }
