Hi all iam working on c51 cygnal microcntrollers iam performing serial communication , at the console iam performing some manipulations and iam updating in an array[255] now i would like to send this array to controller and iwant to write the received array to external memory of microcntroller could you please suggest me how perform this , note i have already established serial communication between console and microcontroller, at the console iam running c programme from that programme i have to send one array to microcontroller.please suggest me how to do this. regards ken
"note i have already established serial communication between console and microcontroller" What does that mean? Do you mean that you can now send something from your PC to the micro controller? So what is your specific problem now? Sending an array is simply a matter of sending each element in turn, isn't it? Similarly for receiving it.
Hi neil thanks for your reply. well actually at the receiving end ie microcontroller how to receive this array in microcontroller. actually my project involves the following 1) at console iam performing some overhead calculations and also i will take data from user, at last iam sending through serial port assume sarray[]={01,1e,30,30,12,32,21,31,38,84,18,32,47,12,3487,12,34,80} actually this type of array is generated at console using c programme .and at last iam writing the each element of array to serial port , ie for(i=0;i<len;i++) { ch=sarray[i]; outportb(port1,ch); } at microcontroller end its waiting to receive this array how to receive this array can i directly initialise an array in the micrcontroler will it store these datas regards narasimhajb
Think about it: When you send an array, you take each element in turn & transmit it. Receiving is purely the converse - you receive each element in turn.
hi neil do you have any documents regarding this ? regards ken
There are several serial comms examples on this very site.
Note that you can set up the simulator so that it uses the PC's serial port for the simulated UART. Thus you can load your code into the simulator and connect the simulator's COM: port to the COM: port that your PC software is using, and debug the whole thing without needing any target hardware at all! You might find this easier than downloading to the real target?
Please read the instructions on the 'Reply' form - they tell you how to post code.
