some trouble whith the use of isr_send_signal()
HI,
I think I have some trouble whith the use of isr_send_signal(), if the task is already in "active state".
Please can you tell me what happend in this case :
* Interrupt 0 each 100 ms
* some times, the fonction mesure()take more time than 100 ms :
/* my exemple*/ :
void task_1 (void)  _task_ MESURE_priority_ 1
char i;
while (1)
	i=os_wait(K_SIG,0,0);
	if(i==3)
		os_clear_signal(EVT_1);
		Mesure();
void itext0(void) interrupt 0 using 1
isr_send_signal(EVT_1);
  • HI,
    I think I have some trouble whith the use of isr_send_signal(): A task is already in a "active state" at the same time when isr_send_signal() to start this task is effective.
    * Interrupt 0 each 100 ms. This programm use 'isr_send_signal' to start task_1, so the mesure() fonction is called each 100 ms.
    * But some times, the fonction mesure() takes a little more time than 100 ms : So what happends !
    /* my example*/ :
    char i;
    while (1)
    	if(i==3)
    		Mesure();
    Thankyou for somebody HELP !
