Hi there, I'm new to all this so bare with my ignorance... I'm currently trying to read and write to the EEPROM on my T89C51RD2. The read function seems to operate correctly but I'm not having so much luck with the write function. Here is my code:
/*------------------------------------- Return EEPROM Byte at address 'adr' -------------------------------------*/ unsigned char ReadEEPROM (unsigned int adr) { unsigned char v; EECON = 0x02; // enable EEPROM v = XBYTE[adr]; // read value EECON = 0x00; // disable EEPROM return (v); } /*------------------------------------------ Write EEPROM Byte 'val' at address 'adr' ------------------------------------------*/ void WriteEEPROM (unsigned int adr, unsigned char val) { int i; EECON = 0x02; // enable EEPROM and set write bit EETIM = 0xC8; // Set EETIM to 5x Fxtal (40 Mhz) XBYTE[adr] = val; // write value EECON = 0x52; EECON = 0xA2; while (EECON == 0xA3); // wait until value programmed EECON = 0x00; // disable EEPROM }
Its ok. I found this... and it works fine. http://www.keil.com/forum/docs/thread477.asp Laters.
My emulator micetek Easypack/E II 8052F can't support EEPROM data RD/WR function,so I must download my code to the cpu and run it in board? The cpu is ATMEL 89C51RD2-CM,is it the T89C51RD2? And the programmer is lab tool-48,its software vertion is V4.67,the device of T89C51RD2 for selecting is only TEMIC,I don't know whether they are the same device? I can't get right EEPROM data RD/WR using your means,so could you give me some advice?
