help! why?
my codes:
unsigned int i=0;
void Timer(void) interrupt 1
    i++;
void Main (void)
    while (1) printf ("i=%d\n", i);
I had thought that I will get below on serial window
i=0;
i=1;
i=2;
i=3;
but I got
i=0
i=-9472
i=-28416
i=29184
i=10240
i=-8960
i=-27904
i=29696
i=10752
i=-8192
i=-27392
i=30464
i=11264
i=-7680
these values are disorderly and unsystematic, why? You had better try it on your own keilc.
  • hi,
    firstly, about disorderly and unsystematic. You know, printf() is not simple function which produce result by one assembly command. Processing format string and sending result via COM-port - it all take alot of time. Ofcoz timer does not wait till printf() will be done; so for time within printf() sends a byte, timer may be increased many times. As result you will get randomize values of i variable.
    well, now about negative values. In fact %d prints both negative and positive values depend on bit 15 of i variable. Printf() does not know about your unsigned declaration. If you wish to print all positive values so you should use %ud or %u (it depends on compiler you use).
    Good days!
  • hi,
    Good days!
