When I try to build a target (Target1) the following appears in the build window Build target 'Target 1' linking... and nothing happens afterwards. Most of the menu items are greyed out. I cannot use debug since no object file is created. I use µVision2 V2.38a Evaluation Version
Have you complied with the published limitations of the eval copy? Have you attempted to use lib routines such as float that are not supported in the eval copy? Will the standard examples included in the software build? Bradford
I complied with evaluation requirements. I am only able to compile the program at the third or fourth attempt ie. after restarting the uVision three or four times. I am totally lost
