Hi, The compile error is: WARNING L15: MULTIPLE CALL TO SEGMENT SEGMENT: ?PR?_STRTONUM?PARSE CALLER1: ?PR?TC0?PERIPHERAL CALLER2: ?C_C51STARTUP The callers TC0 is an ISR using reg bank 2 and I don't know about the c51startup. The called function STRTONUM is using the directive of #pragma NOAREGS so can be called for any functions. The question is why I still got the multiple call error? Thanks for answering my question. By the way, C51 is V6.21, BL51 is V4.21 and LIB51 is V4.20. chao.
Supplement: I know that C51START is the STARTUP.A51. Function main() also calls STRTONUM function. As the result I have two different functions using different reg banks to call STRTONUM. But still, why would I get multiple call warning since the directive of NOAREGS is used on STRTONUM? Can this warning be ignored? chao.
OK, after I read some threads and I found out one thing: both interrupt and non-interrupt functions call the STRTONUM function. Under this circumstance, I should do something "reentrant" on STRTONUM since STRTONUM can be called "at the same time". Am I correct? By the way, it seems there was some one tried to response my question unfortunately I could not see the reply. Thanks anyway. chao.
