So let me see if I have this straight. To use the 2Kbytes On chip XRAM (accessed as XDATA memory space) on a ADuC831, I need to 1) Copy START_AD.A51 into my project folder 2) Add this file to my project so that it will be used on startup as opposed to the STARTUP.A51 file. 3) Make sure that the START_AD.A51 has the XRAM enable bit set to 1. 4) Make sure that the extended stack pointer is not used. 5) write code and compile. At this point, I should be able to reference the 2Kbytes of XRAM by just assigning variables to the XDATA memory space. My project does not require any more than this 2K of XRAM space. So my question is.. Does the compiler know to place XDATA variables in ONLY the lower 2K of the XDATA space? Theoretically the chip can at least address 64K and up to 16MB of XDATA. In addition, how can I verify proper functionality in the debugger? Any help appreciated... MG
At this point, I should be able to reference the 2Kbytes of XRAM by just assigning variables to the XDATA memory space. Yep. That is exactly correct. Does the compiler know to place XDATA variables in ONLY the lower 2K of the XDATA space? Actually, the compiler doesn't set the location of variables. That's the linker's job. The linker puts stuff into the part of xdata that you tell it to. So, if you tell the linker that it can put xdata from 0x0000-0x07FF, then that's what the linker uses. If there is too much stuff to fit there, the linker generates a warning. There are several ways you can set the range for xdata (and other memory spaces). Any one of the following will work.
Thanks for the reply... My version of uVision is 2.31 and my compiler version is 7.01. I think my older version dose not automate the onBoard XRAM capability as the Target/Option/Target dialog does not offer a check box for USE ON CHIP XRAM. I will try the second option (setting the Off Chip XDATA Memory to 0x0000 to 0x07FF) and see if it works. MG
My version of uVision is 2.31 and my compiler version is 7.01. I think my older version dose not automate the onBoard XRAM capability as the Target/Option/Target dialog does not offer a check box for USE ON CHIP XRAM. Yeah. We are constantly adding new information to and updating the information in the device database. You can download the latest update from the web, too. Jon
