Hi. I am using the Keil "OBJECT TO HEX FILE CONVERTER OH51 V2.6" to convert the OMF file to an Intel .HEX file to download into the C8051F120 part using the Cygnal IDE v1.8. I have a bootloader at address 0000H and the application I am downloading starts at 0C00H. All worked well until my application code got larger. It is now approx. 62k and the bootloader now fails with "Checksum Failure" after a certain number of bytes while downloading the .HEX file. Could there be a problem in the OH51.EXE converter? I downloaded the .HEX file generated from OH51 directly using the Cygnal IDE, without my bootloader, and it fails to execute. I am stumped. Any advice on what I should try? From my point of view it seems like the OH51.EXE isn't generating the correct .HEX file when my app is in the 60k range. That just might be a symptom of something else though, I don't know. Anyone have any ideas? Thank you very much.
Cygnal F020 devices have 64K flash, howewer, the addresses from 0xFDFD and above cannot be used for code storage. Check linker map file (*.m51 or *.map) that your code ends BEFORE 0xFDFD... regards Dejan
This is good to know. I didn't find where this was documented. Could you point it out so that I can put a comment in my code? Thanks.
