Hi All, I am hoping someone can inform of how to go about displaying the contents of the interrupt vector table (IVT)on the stdout. I'm taking an introductory class in assembly language, and this is our fourth lab. My instructor wants us to print out the first 40 vectors of the IVT, the contents of the registers at the point the program is running and whether or not the flags are set. The output should look something like this: ***********INTERRUPT VECTOR TABLE*********** 0000H 00C9:0F9EH 0001H 00CA:0F9FH NOTE: There should be 4 vectors per line, but because of space I only show 2 above, 0000H and 0001H. ***********REGISTER CONTENTS**************** DI = hex value SI = hex value BP = hex value SP = hex value BX = hex value DX = hex value CX = hex value AX = hex value *************FLAG BIT SETTINGS************** CF = On or Off PF = On or Off AF = On or Off ZF = On or Off SF = On or Off TF = On or Off IF = On or Off DF = On or off Thanks, Chauncey
