I'd like to know what i have to do in order to use 64k external RAM with the ST10F168. Thanks
Can you ask this in a more clearer way. Do you mean how to wire or how connect chip select lines or something like that ?
A great C166 family design guide is available on the web: http://www.hitex.com/pdf/166GUIDE.PDF There you will find the answer to your question and much more. Regards, - mike
I'd like to know what changes i have to do in the START167.A66 to use 64k of external multiplexed 16 adresses/8 data memory with the st10f168. It's the first time I use the Keil tools and I'm a bit lost. Thanks
Hi this is really not important, since the startup is very good explained by commends. Take a copy in your project folder - open the startup file and look for example at
$SET (BUSCON1 = 0)
_BTYP1 EQU 3
