Is a label local or global? For instance, two functions aa1() and aa2() are in file aa. A label L is placed in aa1(). Another function bb() is located in bb file. Which function(s) can access the label L? Thank you for aswering my question. chao.
"Which function(s) can access the label L?" The short and direct answer is, aa1().
Thank you, Dan. Another question, how do I declare a variable to store the address of a label? chao.
Another question, how do I declare a variable to store the address of a label? You don't. There's nothing you could safely do with that value once you had it, so there's no point acquiring it in the first place. If you really want to write 100% spaghetti code, write assembler code, not C.
Another question, how do I declare a variable to store the address of a label? Why don't you explain what you really want to do? It sounds like you are about to attempt something very dangerous.
