Fail in Licensed Compiler / I/O Error On Input File Code:L210
Have got this message when I try to build my sample project, blinky.
Well, I have bought a full licensed CA51 V7.0, installed it with an online registration completed, and still I got this message at the bottom.
Any ideas guys?
Regards,
JM
Build target 'Simulator'
compiling Blinky.c...
BLINKY.C(1): warning C500: MISSING DEVICE (SECURITY KEY NOT FOUND)
assembling START900.A51...
linking...
BL51 BANKED LINKER/LOCATER V5.03 - SN: C1D6P-58164E
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2002
"Blinky.obj",
"START900.obj"
TO "Blinky"
RAMSIZE(256)
*** FATAL ERROR L210: I/O ERROR ON INPUT FILE:
EXCEPTION 0021H: PATH OR FILE NOT FOUND
FILE: Blinky.obj
Target not created
  • "Well, I have bought a full licensed CA51 V7.0"
    As you have a licence, you should speak direct to Keil support.
    See the 4th bullet-point on the Terms of Use for this forum:
    http://www.keil.com/forum/terms.asp
    Does the licence require the use of a hardware key, or "dongle?"
    This message indicates that your tools were looking for a "dongle," and didn't find it.
    As always, you need to address this first message first - it is certainly the root of all subsequent problems!
    Did you have the "dongle" fitted?
    Does your Operating System require the installation of a driver for the "dongle?"
    Have you tried the "dongle" test utilities in the downloads are of this site?
