Unexpected output from "sizeof"
Could someone please explain the following:
I tried using sizeof command to find out the size of the an int variable by
printf("%d\n", sizeof(int));
I was expecting an output of 2. But interestingly the value that I got was 512. Can anyone explain the significance of this value?
I tried testing the the size of other variables and I discovered something interesting. 512 in decimal is actually 0200 in hexadecimal. Ignoring the last two bytes, the first two bytes actually gives the value 2 which I was expecting.
Similarly, for the size of a character, the value I got was 256. When converted to hexadecimal it is 0100. Looking at the first two bytes actually gives the data size.
Could someone please enlighten me why is this so?
  • "... the value I got was 256. When converted to hexadecimal it is 0100. Looking at the first two bytes [sic] actually gives the data size."
    Note that you mean the first two digits - not the first two bytes!
    A sinlge hex digit represents (up to) four bits; ie, half a byte - widely called a "nibble"
