Hi, A question regarding C51 v6.23a... The C51 manual suggests that, using the 'large' memory model, sprintf is restricted to a 40 byte parameter list. Having used this knowledge to resolve a bug whose presence is caused by a sprintf call exceeding the 40 byte limit, I was curious as to why the compiler hadn't warned me of this situation. It does seems however, if a sprintf call is made using more than 32 arguments (i.e. irrespective of actual byte count) the compiler does warn of this situation. What gives? Is the restriction byte oriented (as I suspect), in which case why no compiler warning for erroneous sprintf calls, or is it argument count related, as the compiler seems to treat it? Thanks for any illumination. David
I remember hitting a similar problem with a function that had variable argument list - one that I had written myself in this case. I overran the limit without getting any warning from the compiler.
Yes, it's very odd that the compiler doesn't emit any kind of diagnostic. It's worse in the small model - 15 bytes I seem to recall. It happens because fixed memory locations are used to pass parameters to scanf, printf and friends. I'm pretty sure this number can be increased but I can't remember how, and 15 seconds of looking at the manual hasn't helped. Stefan
