Please help me solving my problem with the CAN-interface of the C164_CI! Using the Simulator it seems to work well! But using the Monitorprogramm following will happen: -writing to register C1IR (the IPC-bit-field)won't have any effect,allthough the CCE is set!?So CAN will not be onnected to the respective Pins. -writing the CAN-ID of object 15,10,...,1 will work,but the others will cut the connection to the board... -the baudrate will be different using the simulator or the monitor?? -when I use the 'GO'_button in the monitor the connection will be lost too when I stop it... I tried using the Flash memory of the board but it won't work too! Asking the technical support didn't help! I really would be Pleased if somebody would help me!!!!!!! P.S. A project configured by DAVE shows the same behaviour ! Thanks a lot hannes
