Running from external flash
Hi!
I'm using the MCB167-NET. I have done a program using the serial port, so I use a simulated serial port to communicate with the PC using Monitor.
Actually, I have burned an external Flash with the monitor program, and I download the program to the RAM every time I want to run it.
I want to burn my program in external Flash without monitor (I don't need communicate with a PC). So, everytime I switch on the board, my program will run. Is it possible? Do I have to keep the monitor in Flash?
Thank you.
