my program code exceed 8k ,and happened the message "FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEED, MODULE: E:\PROGRAM FILES\C51\LIB\C51S.LIB(-), LIMIT: 0800H BYTES". I have set "LARGE:64k program" from soft targe of code rom size, but still happened the message "L250" in output window! So, what can i do next?? Is any one can help me, please??? thank you very much !
Read what the error message tells you. You have reached the limit of the free version. You have to pay for the product to compile larger projects.
I have already payed for product, I mean that if I have got the licence for KEIL C,and what's the problem it is ?? Is any problem with my seting?? Is any body could tell me? Appreciate a lot ...
[Original question] : my program code exceed 8k ,and happened the message "FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEED, MODULE: E:\PROGRAM FILES\C51\LIB\C51S.LIB(-), LIMIT: 0800H BYTES". I have set "LARGE:64k program" from soft targe of code rom size, but still happened the message "L250" in output window! So, what can i do next?? Is any one can help me, please??? thank you very much ! [New question]: I have already payed for product, I mean that if I have got the licence for KEIL C,and what's the problem it is ?? Is any problem with my seting?? Is any body could tell me? Appreciate a lot ...
Are you using the PK-LPC8K Version? Jon
Do you have the dongle connected to your PC? If yes, and you're running Win2000 or XP, do you have the necessary drivers for the dongle loaded? (I think there is some extra patch available on this website for XP)
