I had downloaded the example: Application Note 161(APNT_161.ZIP) But I can't work under my uVison7.01 The result in memory windows is not correct. Can anybody help me? thanks a lot.
"Can anybody help me?" Not from the very limited information you've given!! "I can't work under my uVison7.01" Why not? What stops you? "The result in memory windows is not correct." In what way is it "not correct?" What do you get?
Thank you. I will try again.
