User defined memory space
Hi all,
I'm asking if anyone has found a better way to access user defined memory. That is, accessing memory that can't be reached w/the "movx" instruction, but must be accessed w/user code.
I can get it done w/Far memory but don't want to buy the PDK.
I finally found that I can use good old C51.exe & BL51.exe and generic pointers to get the job done. I can divide XDATA space into "standard" RAM and user defined RAM by writing my own ?C?CSTPTR & ?C?CLDPTR routines (these library routines resolve generic pointers at run time).
This can get tedious (using pointers when I normally didn't have to) but it works. My main problem is that I have to be careful to use or store parameters passed between functions (via registers) right away or the compiler will store them in XDATA w/MOVX - which can cause trouble depending on the address.
Anyway, if I'm careful this works. And, I don't see any other way to do this aside from buying the PDK.
Has anyone else ever done this another way?
Thanks for your time.
Bill
