I'm using a Philips P89C662 that provides In-system Application Programming (IAP) with have an entry address at 0xFF00. I am trying to read proram boot vector information. I an not sure how to refer to registers R0 & R1. R0 register is set to FOSC and R1 is set to 06 for boot vector. All other registers are defined in the reg66x.h file. Registers AUXR1, DPL, DPH are alredy defined. Only R1 & R2 are not defined. typedef void (*pgm_mtp_ptr)(int); pgm_mtp_ptr iap_call = (pgm_mtp_ptr) 0xFFF0; unsigned char vec; AUXR1= 0x20; /* set the ENBOOT bit */ R0 = 18; /* FOSC */ R1 = 0x7; /* Read Misc Function */ DPH = 0x0; DPL = 0x2; /* specify boot vector */ vec = 0; /* init vec to zero */ vec = iap_call(); /* call PGM_MTP @0xfff0 */ I am getting error C2002: 'R0' and 'R1' : as undefined variables. sfr R0 = 0x0; sfr R1 = 0x1; Cannot define using sfr as 0 & 1 as compiler complains about invalid base addresss. Can some one point to me as to how to set the various IAP commands in Register R1 ????? Thanks, Venkat
Can some one point to me as to how to set the various IAP commands in Register R1 ????? as clearly shown in AN471 that is done in assembler. Erik
Hi Erik, Thanks for your mail. Phillips document on P89C66X shows assembler code. I have driver in assembler code that works just fine. I am converting the assembler code into Keil's c code. As I pointer out earlier Keil complier cannot interpret registers R0 & R1. One way I can set the values is by dropping into assember. #pragma asm MOV R0, #18 ; FOSC MOV R1, #07h ; Read Misc Function #pragma endasm Rest of the code is the same as I indicated earlier. I will try this out to see if I can get the boot vector information. Thanks, Venkat
I am converting the assembler code into Keil's c code. That begs a question: why? Why bother converting it? You can just put that assembly code into an assembly-language source file and add that to the project, instead. It's bound to be a whole lot simpler to get working, that way.
It is an absolute fact that, in order to make 'canned routines' work across various platforms the interface must be in assembler. e.g. were I to write some routines and supply them in object only, I doubt that they would work called from C regardless of e.g Keil with or without NOREG , Raisonance, GNU or IAR. Thus 'converting a foreign routine inteface to C' is a futile excersise. Erik
"That begs a question: why?" Absolutely! Fiddling about with processor registers (as opposed to peripheral registers) is almost always best done in assembler. Remember, the 'C' compiler is free to use the processor registers in whatever way it sees fit - so, just because you somehow manage to force your value into R0 there is no guarantee that the same value will still be there by the next 'C' statement!
Take a look to Knowledgebase article C51: INTERFACE FOR IAP FUNCTIONS ON PHILIPS DEVICES at http://www.keil.com/support/docs/2045.htm. Maybe this small interface routine helps you to solve your problem.
