snmp agent for 8bit CPUs
Thu Apr 03 2003
DMH Software announces the availability of its portable SNMP Agent
(snmpv1, snmpv2c, snmpv3) and SMIv2 mib-compiler for 8bit CPUs. See
more information here:
http://www.dmhsoftware.com
http://www.dmhsoftware.com/snmp.html
Our highly portable Advanced SNMP Agent code can now be compiled by
8bit compilers (e.g. 8051) and be integrated and used in small systems
based on 8bit CPUs.
We have made changes to meet the 8051 CPU architecture but have not
compromised feathers or protocol completeness. A set of compile-time
flags allow you to reduce the code and data size to meet memory
restrictions.
Specifically, we built and tested the SNMP Agent code by the popular
Keil "C" compiler for 8051.
You can compile the same SNMP Agent code for w32 or Linux platforms.
This will allow you to develop the support for your MIBS in a
convenient development platform. Once your snmp-agent is tested you
can compile it for your 8bit target.
DMH SNMP Agent is designed for real-time embedded environment. It is
designed to work with any given tcp/ip stack and can be easily
integrated with to your tcp/ip stack of choice. It does not require OS
services.
We offer to integrate our snmp-agent to your system and the tcp/ip
stack you use. Please contact us.
For more information and questions please contact me.
Best regards,
Yigal Hochberg
DMH Software
15 Arborwood Rd, Acton, MA 01720
Voice: 978-263-0526 Fax: 801-760-9746
mailto:hochberg@dmhsoftware.com
