Bug in C51 Version 7.05
Dear all,
I would like someone to confirm this bug:
unsigned long b, d;
unsigned long Round2(unsigned long value)
  unsigned long WholePart;
  unsigned char Remainder;
  WholePart = value / 10L;
  Remainder = (unsigned char)(value % 10L);
  if (Remainder > 4)
    WholePart++;
  return (WholePart);
void main(void)
  b = Round2(456756);
  d = Round2(456751);
  do {} while (1);
When I compile the program (Level 7, 80C32), I get the following code for the Round2 function:
             ; FUNCTION _Round2 (BEGIN)
                                           ; SOURCE LINE # 3
0000 8F00        R     MOV     value+03H,R7
0002 8E00        R     MOV     value+02H,R6
0004 8D00        R     MOV     value+01H,R5
0006 8C00        R     MOV     value,R4
                                           ; SOURCE LINE # 4
                                           ; SOURCE LINE # 8
0008 E4                CLR     A
0009 7B0A              MOV     R3,#0AH
000B FA                MOV     R2,A
000C F9                MOV     R1,A
000D F8                MOV     R0,A
000E 120000      E     LCALL   ?C?ULDIV
0011 8F00        R     MOV     WholePart+03H,R7
0013 8E00        R     MOV     WholePart+02H,R6
0015 8D00        R     MOV     WholePart+01H,R5
0017 8C00        R     MOV     WholePart,R4
                                           ; SOURCE LINE # 9
0019 E4                CLR     A
001A 7B0A              MOV     R3,#0AH
001C FA                MOV     R2,A
001D F9                MOV     R1,A
001E F8                MOV     R0,A
001F AF00        R     MOV     R7,value+03H
0021 AE00        R     MOV     R6,value+02H
0023 AD00        R     MOV     R5,value+01H
0025 AC00        R     MOV     R4,value
0027 120000      E     LCALL   ?C?ULDIV
;---- Variable 'Remainder' assigned to Register 'R7' ----
                                           ; SOURCE LINE # 11
002A EB                MOV     A,R3
002B D3                SETB    C
002C 9404              SUBB    A,#04H
002E 4015              JC      ?C0001
                                           ; SOURCE LINE # 12
                                           ; SOURCE LINE # 13
0030 E500        R     MOV     A,WholePart+03H
0032 2401              ADD     A,#01H
0034 F500        R     MOV     WholePart+03H,A
0036 E4                CLR     A
0037 3500        R     ADDC    A,WholePart+02H
0039 F500        R     MOV     WholePart+02H,A
003B E4                CLR     A
003C 3500        R     ADDC    A,WholePart+01H
003E F500        R     MOV     WholePart+01H,A
0040 E4                CLR     A
0041 3500        R     ADDC    A,WholePart
0043 F500        R     MOV     WholePart,A
                                           ; SOURCE LINE # 14
0045         ?C0001:
                                           ; SOURCE LINE # 16
0045 AF00        R     MOV     R7,WholePart+03H
0047 AE00        R     MOV     R6,WholePart+02H
0049 AD00        R     MOV     R5,WholePart+01H
004B AC00        R     MOV     R4,WholePart
                                           ; SOURCE LINE # 17
004D         ?C0002:
004D 22                RET
             ; FUNCTION _Round2 (END)
Notice the result for source line 11, which should be:
002A EB                MOV     A,R7
as the comment just before correctly says.
Thanks in advance,
José Sánchez del Pozo
