Hi! I have some problems linking my program on a P5MX Chip with the LX51 V3.54. All my files are compiling succesfully and I want to use a linear addressing without banking and I have the following error : ERROR L210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: D:\KEIL\C51\LIB\MX51BANK.OBJ Do I need this file anyway with no banks settings or is there a solution to link without this file?
You must include MX51BANK.A51 in your project and you must configure it for the number of banks of code space. Jon
Take a look to Application Note 160 ("http://www.keil.com/appnotes/docs/apnt_160.asp"). It explains the ROM HUGE mode that does not require this banking file at all.
I already use the ROM(HUGE) Directive. here are my compilation options, perhaps, there is a problem with some of these : AX51 = DB XR LI OJ($@) MOD_MX51 CX51 = PRBROWSE DB OE CD NOIP ROM(HUGE) SMALL OT(9,SPEED) OJ($@) RF(proj.REG) LX51 = TO proj.ABS CLASSES (XDATA (0x000000 - 0x0007FF), ECODE (0x800000 - 0x817FFF)) SEGMENTS(...,...,...,) IXREF SY DL RF(proj.REG) Thanks.
