Phytec KC167CR debug problems
Hi all.
I am experiencing some problems with debugging my code on my Phytec evaluation board. I run the RTX166 Traffic-example.
I'm using Keil Monitor-166 with the KC167CR config. In the description of this config, I am recommended to reserve memory 8H-0BH, 0ACH-0AFH. External memory is set to ROM: 0x0 - 0x10000 and RAM:0x10000 - 0x20000.
When doing rebuild all for target RTX Tiny, the linker gives me the warning:
Warning L4: Memory space overlap from 0000ACH.0 to 0000B0H.0
This is probably due to the memory reservations I did before. Should I remove the reservation?
If I remove 0ACH-0AFH from reserve memory, It builds fine and everything seems OK. When I now start the debugger, it loads fine, but running the program ends with some rubbish to the serial #1 screen, some LED's lighting up, and then it all comes to a dead end. I can't debug or nothing.
I suspect there is something wrong with my memory adressing, but I'm somewhat green to this, and I would really appreciate some help!
Regards,
Ray
