Pointer to Structure with pointer.
I'm having a problem with a pointer to struct. I'm working with the PC16552 UART, (it has 2 UARTs), and I created a struct for each UART like this:
typedef struct _uart
 uchar xdata *ucBuffer;
 uchar xdata *ucLineCt;
 uchar xdata *ucLineSt;
} uart;
Each uart is conected to a different external interrupt, and when that interrupt is generated, it calls a function getByte that have a pointer to a uart struct as parameter:
void int0(void) interrupt 0
 getByte(&Serial1);
void int1(void) interrupt 1
 getByte(&Serial2);
void getByte(uart *actualSerial) reentrant
 unsigned char ucByte;
 ucByte = *actualSerial->ucBuffer;
It works fine, but sometimes, I receive a wrong character. I was thinking that could be hardware, but I decided to make a dump of the block, and the dump solved the problem. I'm asking help, because I don't know what is it, if it's hardware or firmware... The problem occurs when I receive a 0xFF from the serial 2... Sometimes, it turns in 0xF7 or 0xF3. In the dump, I simply do this:
 if(actualSerial == &Serial2)
  if(i < 20)
  Dump[i++] = ucByte;
