adding a assembly file to project
Hi all
I want to add Asm file to a 'C' project.
Project has one '.c'and one '.h' file.
Assmbly file to be added is with '.a51' extension.only one routine is added to a51 file,which is called from main.A51 file is getting assembled successfully,but project is not getting compiled as whole.
decleration in main file is :
extern void delay_asm(unsigned char);
void main()
   delay_asm(2);
Assembly file is as given below
PR?delay_asm?delay_asm SEGMENT CODE
PUBLIC delay_asm
delay_asm:
   USING 0
   mov a,R7
rv:dec A
   Jnz rv
   RET
END
on project compilation:
warning L5:Code space overlap
To:0004H
warning L2:Refrence made to unresolved
external _delay_asm
Target not created.
This warnings where not generated before adding a51 file to project.
i am missing some thing small here,but any help would be appreciated.
Regards
Naresh
