Anyone seen this one? I have a data structure in assembly (bit-mapped font) that I want to reference in C. The 'C' code looks like this:
extern code unsigned char *FONT1;
NAME FONT1 ?CO?FONT1 SEGMENT CODE PUBLIC FONT1 RSEG ?CO?FONT1 FONT1: ... END
What happens when you try this?
extern code unsigned char FONT1 [];
same problem... I've tried several different types in the 'C' code. thanks!
Is there any problem with "FONT1" being a module name, a segment name, and an address name all at the same time?
I just tried the following simple program and it works great. FONT1.A51
NAME FONT1 ?CO?FONT1 SEGMENT CODE PUBLIC FONT1 RSEG ?CO?FONT1 FONT1: DB 'K' ,'e' ,'i' ,'l' ,' ' ,'S' ,'o' ,'f' ,'t' ,'w' DB 'a' ,'r' ,'e' ,000H END
#include <reg51.h> #include <stdio.h> extern unsigned char code font1[]; void main (void) { SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 221; /* TH1: reload value for 1200 baud @ 16MHz */ TR1 = 1; /* TR1: timer 1 run */ TI = 1; /* TI: set TI to send first char of UART */ while (1) { printf ("%s\n", font1); } }
Jon, The only real difference I see in what you have and what I have is the position of the "code" keyword in the 'C' extern statement. I'm not at work right now, so I can't check it out...do you think this is my problem? thanks a bunch! -alex
SO... It turns out that the issue had to do with a bad install of either or both the Keil SW and the Cygnal IDE. I reinstalled both and now its all happy. thanks, ai
The only real difference I see in what you have and what I have is the position of the "code" keyword in the 'C' extern statement. The postition of the code keyword is all important. In this case:
