Hello all, has anybody tried to use CAPCOM6E, if the external bus works in 16-bit multiplexed mode ? Without bus - all works fine. But if I enable the bus and set EBCMODE1 with 0x001F (31d) to decoupling the port1 from bus ( as the manual says ) the CAPCOM6 does not work. Can anybody help me ? Thanks Stefan
Hello, I don't use CAPCOM6 for that, but I would like to use it like software timer but I don't know exactly how. I don't know where can I get a sample code for that. Can you help me, pleas? Thanks a lot.
