Hi.. I use an infineon xc167ci without module. I program it using infineon memtool. I can erase the flash, but I cannot program it. On uVision2 "OPTIONS FOR TAGRGET TARGET1=>L166MISC" there is a linker control string determing how memory of the xc167ci is used. The memory location for program memory is 0xC00000 -> 0xC1FFFF(Datasheet), but uVision always writes some code to 0x018000 -> 0x01803B. I can see that in memtool. The linker control string allows e.g. FCODE, FCONST, HCONST,... to write something to this area. But memtool says error: check memory mapping. What do I have to do? Does that have anything to do with startup stuff, for I use no minimodul, so maybe there's something wrong with pu- or pd-resistors.
Hi Erwin, concerning the ON-CHIP FLASH, ensure you have set under "Options for Target" -> "Target" use on-chip ROM(128KB) use on-chip XRAM (0xC000-0xCFFF) If no external RAM or other memory the external memory entrys should be empty. Than under Linker -> "L166 Misc" only do the entry for the vector table as 0xC00000 . Thats all. But please check your startup file to be sure EBC is enabled. At older versions the userstack was placed in NCODE area, so have look at M66-map file and use the USERSTACKDPP3 directive (C166 manual) if necessary. For the memtool check out you have selected the right target ( differences between step AA,AB ... ) Stefan
Hi Stefan.. Thanks for your answer. I have done as you said, but it did not help. EBC is enabled, and all uVision instructions are as you said they should be. As I checked the M66-File, I found out, that the main-routine is linked to 0x18002H 018002H main LABEL --- FCODE ?PR? test The userstack is in 0x00C000H, what seems to be ok. What can I do to link the main-routine somewhere to 0x00C000H? And what are the differences between AB and AC in memtool? Thanks, Holger
Mhmm, did you set small memory model for your target ? I wonder that you have FCODE - that indicates that your program is an area located where normally a external memory would be. If you do it right than you will see NCODE ?PR?test. Userstack is ok. Otherwise I need your map file or some more informations. Stefan
No, the memory model is large. If you want you can mail your Email-Adress to eins12000@yahoo.de So I can send you the files you need. Erwin
