Hi.. I switched device from a c167sr to a cx178ci. I used a minimudul before, now I want to use the processor without any module. I changed the start*.a66 file and the device for the target. I am not sure what else I have to change...especially what I have to do in "Options for Target XXX -> Debug" The error message Í use to get is: "C:\KEIL\C166\BIN\A166.EXE" "Start_v2.a66" MODV2 MODV2 MOD167 SET (TINY) DEBUG EP A166 FATAL ERROR - LINE: C:\KEIL\C166\BIN\A166.EXE Start_v2.a66 MODV2 MODV2 MOD167 # ERROR: CONFLICTING CONTROL A166 TERMINATED. Thanks, Holger
You have to add to your project Start_V2.A66 instead. For this you need a version C166 4.21 or higher. µV2 will get information for MODV2 from this startup file. So, as Andy says - NO reason to specify MOD167 again. Stefan
