Dear all, Thank you for your help in advance. I created a very simple program to test my Monitor-51 which is showed below:
#include "AT89X55.H" sbit P25 = 0xA5; void DELAY(int j) { int i; for(;j>0;j--) { for(i=2;i>0;i--) {;} } } main(){ while(1) { P25 = 0; DELAY(1); P25 = 1; DELAY(1); } }
... C:0x00AE E4 CLR A C:0x00AF F5CB MOV RCAP2H(0xCB),A C:0x00B1 F5CA MOV RCAP2L(0xCA),A C:0x00B3 F5CC MOV TL2(0xCC),A C:0x00B5 F5CD MOV TH2(0xCD),A C:0x00B7 F5C9 MOV T2MOD(0xC9),A C:0x00B9 F5C8 MOV T2CON(0xC8),A C:0x00BB 20B0FD JB RXD(0xB0.0),C:00BB C:0x00BE 30B0FD JNB RXD(0xB0.0),C:00BE C:0x00C1 D2CA SETB TR2(0xC8.2) C:0x00C3 30B003 JNB RXD(0xB0.0),C:00C9 C:0x00C6 30CFFA JNB TF2(0xC8.7),C:00C3 C:0x00C9 30B0FD JNB RXD(0xB0.0),C:00C9 C:0x00CC 30B003 JNB RXD(0xB0.0),C:00D2 C:0x00CF 30CFFA JNB TF2(0xC8.7),C:00CC C:0x00D2 30B0FD JNB RXD(0xB0.0),C:00D2 C:0x00D5 C2CA CLR TR2(0xC8.2) C:0x00D7 20CFD4 JB TF2(0xC8.7),C:00AE C:0x00DA AFCC MOV R7,TL2(0xCC) C:0x00DC AECD MOV R6,TH2(0xCD) C:0x00DE EE MOV A,R6 C:0x00DF C3 CLR C ...
The LJMP you see is where the reset vector jumps to the monitor program. If you program must start at address 0x8000 (when using the monitor) then you must do more than simply specifying the starting CODE address. Refer to the following knowledgebase article: http://www.keil.com/support/docs/189.htm Once the program downloads to the monitor, you may also have to specify the starting address ($ = 0x8000). It's probably a good idea to uncheck Go Til Mail in the debugger options. Jon
Thank you. My setup is just as what "C51: SETTING PROGRAM START ADDRESS" says and I got the same result. In addition, when I stepped over the program,it halt at
Why does my program always start from C:0x00AE? This question reminds me of a Peter Sellers movie. A man asks an innkeeper, "Does your dog bite?" The innkeeper said, "No." The man leans over to pet the dog and the dog nearly eats his hand off. He turns to the innkeeper and says, "I thought you said your dog did not bite." The innkeeper responds, "That is not my dog." I guess my smart-aleck answer to "Why does my program always start from C:0x00AE?" is, "That is not your program!" Jon
