Hi, I need to use the external interrupts of the LPC932. The micro will be in sleeping mode and will be woke up only by these two events. It works fine the first time, but then it does not work any more for external interrupt 0. Why? Could it be my Port configuration on port 1, which is where these two interrupts are entered. These two pins have to be input only. IT0 = 1; //pulses will be edge triggered EX0 = 1; IT1 = 1; //pulses will be edge triggered EX1 = 1; EA = 1; //EBO = 1; //Brown Out interrupt (IEN0.5) PCONA = 0xEF; // turn off all peripherals that can be turned off PCON |= 0x12; // switch to Power Down mode while(1); Thank you!
Do you really want that while(1) at the end?
This is what I think, as long as pulses are not present on either pin INT0 or INT1, the micro will be in Power D. mode. So I guess it will be always looping right? when a pulse is sensed at one the pins then the micro will wake up and go to the ISR of the respective interrupt. When the ISR has been executed it will go back to power d. mode and so forth. What do you think of this...I mean I am still a beginner so you may have a better or the right idea to accomplish this. Can you help me? thanks
Erik this is what I have main() proc. { ... ... IT0 = 1; EX0 = 1; EA =1; ... ... } Power_Down() proc. { while(1) { PCON = 0x12; // switch to PDM } } ISR for INT0() { PCON = 0x10; //Normal mode .... ... ... } It works with the emulator, but not with out it. Why.
It works with the emulator, but not with out it. 1) first it was simulator, now it is emulator, what is it? ICE/Keil simul/fried apples? 2) how do you know it does not work in real mode? Erik
Erik I tested on both the simulator and emulator and the interrupt was detected when it occurred. It was executed and goes back to PDM. In real it is not doing it, because the pulses are not being counted. I know this because after a certain amount of pulses something is supposed to happen (about 7 seconds) and it does not happen at all. That is why I know it is not working. Makes sense to you?
Makes sense to you? not at all. You keep feeding me tidbits such as I know this because after a certain amount of pulses something is supposed to happen reduce your code to the VERY MINIMUM you need for this e.g. alternate a LED in the main, then go to sleep, wake up in isrEX0. Try it ICE and real, if it does not work post IT ALL. Erik
Erik I went back to read the user's manual and this is what I found. "In power down mode the power supply voltage may be reduced to the RAM keep-alive voltage VRAM. This retains the RAM contents at the point where PDM was entered. SFR contents are not guaranteed to after VDD has been lowered to VRAM." I think maybe since the contents of some registers are lost after entering PDM, the "pulse counter" is never counting because it is always losing its contents...don't you think? So the micro wakes up, but never accumulates the pulses, therefore not working properly. I may be wrong though.
I think maybe since the contents of some registers are lost after entering PDM, the "pulse counter" is never counting because it is always losing its contents...don't you think? how would I know, you never showed it. I have been communicating under the impression that you showed "the whole truth and nothing but the truth". It is annoying to get information in the 25th post, or whatever the number is, that might have cleared the problem in post 3. Erik
"the contents of some registers are lost after entering PDM" That's not what the manual says, is it? The manual says, as you've just quoted, that it's lowering VDD to VRAM that causes the SFR contents to become undefined - not going into powerdown per se. So, the question is: are you lowering VDD to VRAM? Or are you going to keep us guessing on that one for another dozen posts?
What do you suggest Erik. Because I do not know why it does not work?
extract from your program the very least amount of code in assembler (20 or so lines should do) to show the problem. Load that and nothing else and if the problem still exist, post the code. Erik
If you have the Keil LPC900 kit, it includes an example uVision Project for low-power modes. Why don't you give that a try?
Andy, that is where I got the intial sample program from. Then I modified it. Thanks
Erik. I will try what you suggest and let you know
Erik how can I get the assembly code of my program. It is written in C. The external interrupt and Power Down mode work fine when I use the simulator but not in my application.
"how can I get the assembly code of my program. It is written in C" Look on the 'Listings' tab in your Project Options.
Andrew I went to Lintings in project options... and selected assembly code. Now how do I see it on my screen.
