Hi, when the 89LPC932 enters power down mode I want it to wake up only from an external interrupt. Unfortunaltely, this is not happennig. can you help me? maybe I am missing something here in the code. void Min_Power(void) { EX0 = 0; PCONA = 0xEF; // turn off all peripherals //that can be turned off PCON |= 0x12; // switch to Power Down mode IT1 = 1; //ext. inter. 1 edge triggr. EX1 = 1; while(1); }
PCON |=0x12; EX1=1; Do you notice something about the order of events? Stefan
Stefan you were right! I was shutting down everything first and then turning something on. I swithed the order of the events and it worked. Thank you
