Hi, Trying to set up a multi dimensional array to act as a circular buffer. Will copy 8 databytes into the array and increment a write_counter. Then in different module when it comes around to service the buffer it processes each entry until the read_counter == the write counter. My code is below; PRL.c code
#define CMD_RXBUFFER_SIZE 10 //how many entries in my buffer #define CMD_RXBUFFER_WIDTH 8 //ie 8 bytes wide . . unsigned char cmd_rxbuffer[CMD_RXBUFFER_SIZE][CMD_RXBUFFER_WIDTH]; //ie from 0-->49 deep, 8 wide unsigned char rxbuff_write = 0; unsigned char rxbuff_read = 0; . . //then in a function: rxbuff_write = rxbuff_write + 1; //add 1 to current write counter if (rxbuff_write==CMD_RXBUFFER_SIZE) //dont try to allocate data to a non existent array entry { rxbuff_write=0; } memcpy(&(cmd_rxbuffer[rxbuff_write][0]),&DLL_Rx_Buffer.databytes[1],7); //copy the received data to the next available buffer
extern unsigned char cmd_rxbuffer[CMD_RXBUFFER_SIZE][CMD_RXBUFFER_WIDTH]; extern unsigned char rxbuff_read; extern unsigned char rxbuff_write; unsigned char TestData; . . . //then in a function: while (rxbuff_read != rxbuff_write) { rxbuff_read = rxbuff_read + 1; if (rxbuff_read == CMD_RXBUFFER_SIZE) {rxbuff_read=0;} TestData = cmd_rxbuffer[rxbuff_read][0];
rxbuff_write=3;
memcpy(&(cmd_rxbuffer[3][0]),&DLL_Rx_Buffer.databytes[1],7);
You reduced your example a little too much for very precise advice to be possible. The only hunch I have is that your two source files may not have the same idea what your array's dimensions are, because they don't use a single source that defines it. 1) There should never be a need to write 'extern' inside a .c file. Such things belong into header files, where they can be maintained centrally for all modules that may have to access them. 2) Same for #define's of constants that influence types, like your array dimensions, and for type definitions themselves. I.e. you should have a file PRL.h that contains all the "extern" declarations for PRL.h and the array dimension #defines. As to the problematic behaviour itself, I suspect you'll have to look into the generated code to see what it actually does. Another likely reason would be concurrency/reentrancy. Are the two function snippets you showed, by any chance, executed in different context, e.g. one in the main code and the other in an interrupt handler?
Hi, Thanks for your reply. My #defines are actually in a .h file and the declarations are in corresponding .h files too. But I was trying to make it easier to see. But your point about concurrency/reentrancy is true... I first assign the data into the array during an interrupt service routine (when data arrives). then, when my main (while forever loop) gets chance it tries to service each of the array entries. I was able to find a work around using the following code: In PRL.c:
for (x=0;x<=5;x++) //ie copy bits 1-->7 into 0-->6 {cmd_rxbuffer[rxbuff_write][x]=DLL_Rx_Buffer.databytes[x + 1];}
for(i=0;i<=5;i++){Command_Response.Parameters[i] = cmd_rxbuffer[rxbuff_read][i+1];}
