The sample L51_BANK.A51 module uses the following code to determine the current bank:
?B_BANK&N: MOV A,?B_CURRENTBANK ANL A,#?B_MASK CJNE A,#BANK&N,XLABEL ; etc...
?B_BANK&N: CLR A ORL A, ?B_CURRENTBANK ANL A,#?B_MASK CJNE A,#BANK&N,XLABEL ; etc...
hi, ORL A, ?B_CURRENTBANK is not R-M-W instruction because destination is not a port but the acc. Good days!
If that's the case, then it's necessary to store a copy of the current bank somewhere else. But, back to my original point, is the L51_BANK code incorrect?
Seems so. In fact, if current loading of P1 is not so much (for example, if 74N244/245 buffer used) then it is still correct because you will read value from pin same as from latch. Anyway, some MCU have different input/output schemes and reading from pin which previously was set to 0, does not guarantee same value back. Yeah, seems it is error really. Good days!
