Hi,all Can anyone tell me how to set VSS in Keil C51,My version is 7.06a I read the manual ,but can't success anyhow,Please help me!
Can anyone tell me how to set VSS set the supply voltage (Vss) by code ??? Something here does not make sense Erik
I assume you are talking about MS Visual Source Safe. Which Version are you trying to use?
Hi,Matthias: Yes,I do mean Visul Source Safe. I try to use versio 6.0. Could you help me use it? Maybe you can give me some samples,But I used the templete with Keil C51, it didn't work.It always tells me "can't execute"! What's wrong? I,sometimes,can checkin,but vever checked out successfully. Thanks!
For the support of VSS Version 6 in µVision2 you will have to wait for the C51 V7.07 Update. This will also bring a new template for VSS 6.
Thanks any way,Matthias! But can't we make a templete by ourselves?
Yes, you could do this. But also a new Version of µVision2 is required to support VSS6. http://www.keil.com/support/docs/2642.htm
