Problem on linking Monitor51
Dear all,Can you help me?Thank you in advance!
I used uVision(Keil C51 V7.01) to connect to Monitor-51 which was made by myself.But it didn't work.When I built my project,it showed as below:
Build target 'Target 1'
assembling mon51asm.a51...
assembling STARTUP.A51...
linking...
*** WARNING L5: CODE SPACE MEMORY OVERLAP
TO: 8013H
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
SYMBOL: ?C_START
MODULE: STARTUP.obj (?C_STARTUP)
*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
SYMBOL: ?C_START
ADDRESS: 801EH
Program Size: data=9.0 xdata=0 code=32803
creating hex file from "mon51test"...
"mon51test" - 0 Error(s), 3 Warning(s).
Then I started debug session in spite of the warnings,it show "ERROR 22:NO CODE MEMORY AT 0x8000".And the uVision couldn't connect to Monitor-51.How should I solve this problem.Thank you very much for your advice.
