Hi every body. Is it possible to use the USB port for the ISD-51 instead of the UART port? (The UART port can serve also as GIO). Thanks Kobi.
What USB port?
I am using the uPSD of ST. This device includes Intel 8031 microcontroller. Is there any way to use the USB port intead of the UART port( The UART port can also serve as general I/O port). Thank you Kobi
ISD51 was designed to use the serial port only. USB was not used because the setup is significantly more complex (on the target as well as on the PC) and there are only a few devices with on-chip USB. Jon
Thank you very much. Kobi
