#include "reg51.h" main() { bit k; k = ACC^7; //this instruction is right . ACC^7 = 1; // this instruction is wrong! why? } thank you !
Neither of your statements does what you intend... The "^" character only means "bit position" within an sbit declaration. Everywhere else it has its standard C meaning, which is the exclusive OR operator. So "k = ACC^7;" means take the ACC register, XOR it with 7, then truncate the 8 bit result to one bit and place into k". "ACC^7 = 1;" is a nonsense statement in C terms.
So "k = ACC^7;" means take the ACC register, XOR it with 7, then truncate the 8 bit result to one bit and place into k". Actually, I don't think that's correct. In an assignment to a bit type the right hand side is treated as a boolean type, no truncation occurs. Assignment of any non-zero value to a bit variable results in the bit being equal to one. Stefan
You're probably right there Stefan, I was making an assumption. Still, it is not what she was intending I'm sure.
Note: ACC^7 is an expression (its meaning already explained), it is not "left_value" (it has no address => no write is possible), therefore you can't write :
ACC^7 = 1;
#include "reg51.h" sbit ACC7 = ACC^7; // first define bit of a bitaddressable base main() { bit k; k = ACC7; // I think this was your ACC7 = 1; // primary intention ? }
