I use the SLOG function to do some printf in an ouptut file but how is it possible to do some scanf in another file (input file)?
What is the 'SLOG' function? Can you explain what your problem is a little more clearly? Stefan
In µVision2 Debug Commands SLOG is: "SLOG > path filename" "Creates the file filename as a log file. Input and output from the Serial window is written to this file. " This is very useful to 'simulate' the printf on simulator or evaluation board The problem is how to write some values in one file (simulate the printf) and read some value in another file(simulate the scanf) by example for dhrystone test.
Sorry, I don't know much about the debugger. Hopefully someone else will answer your question. Stefan
