Saving Return Address on User Stack
I've read the article that there is no support in the C167 KEIL compiler. Hence, I've tried to use MACRO assembler as follows.
*DEFINE ( calls(Rx, Ry) ) LOCAL RETURN_LBL (
MOV R13, #SOF %RETURN_LBL
MOV [-R0], R13
MOV #%Rx, #SEG %RETURN_LBL
MOV [-R0], R13
JMPS SEG #%Rx, SOF #%Ry
RETURN_LBL:
I have no translate error. However, it doesn't work. Is it possible to define an operation to another set of operations?
  • Is it possible to define an operation to another set of operations?
    There doesn't seem to be a straightforward way to do that. Just one thing that comes to mind: configure the IDE to 'generate SRC and assemble it', replace A166.EXE with a stub that would do preprocessing on SRC file first and call real A166.EXE next.
    - mike
    - mike
