Hi, I am using the MCB900 with the P89LPC932 microcontroller and I wanted to install an external crytal. After having it installed, I went to Flash Magic and selected from the ISP menu the "Device Configuration" option and then I selected "slow crystal...3 to...KHz" After doing that and trying to run the microcontroller, it does not work at all. The board is not working right. Does any one know what happened there. any ideas... I put a new micro controller, but still is the same.
