Hello! I've got the problem that the same code works different in debugging mode and in "normal" stand-alone mode. In debug mode - with or without any breakpoints - all works nice, but when I disconnect and run the program stand alone it doesn't work. I use the F020 with µVision2 V2.37 and C51 V7.05. Thanks for any hint! Astrid
You really will have to be more specific. "It doesn't work" has not ever been a useful description of any malfunction, and probably never will be. So: 0) What does "it works" mean to you? I.e. what does your program do? 1) How exactly does it fail? 2) What "debug mode" are you talking about? MON51?
Ok, I see, my desciption is poor ;-) I use for debugging the Cygnal C8051F Driver, newest version. This is my code:
main() { if ( RSTSRC == 0x08 ) { WDTErrorFlag = 1; Initialize(); ShowError( E_WD ); Wait1Min(); WDTErrorFlag = 0; RSTSRC = 0x10; } else { WDTErrorFlag = 0; DoSomething(); } }
I don't know that particular chip. But this:
RSTSRC == 0x08
(RSTSRC & 0x08) == 0x08
There is nothing in your code that prevents the program from exiting the main function. Perhaps that is the cause of the second "reset". Typically, the main C function for embedded programs is implemented as follows:
void main (void) { whilw (1) { /*** do something ***/ } }
