1 open project HELLO 2 insert int e,b,c; after main 3 in project devce select extended linker 4 translate 5 debug and see that variable e ????? what is it? is it new version?
I did as you suggested and I receive the following compiler warnings:
*** WARNING C280 IN LINE 24 OF HELLO.C: 'e': unreferenced local variable *** WARNING C280 IN LINE 24 OF HELLO.C: 'b': unreferenced local variable *** WARNING C280 IN LINE 24 OF HELLO.C: 'c': unreferenced local variable
for example add line e=10; and you will see the same question ???? e-> ??????? what is it ;-)
Please send me your c and uv2 file a don't to achieve your results so I probe with your files. holatron@seznam.cz
send mail for you
There is an update for this on keil site now
