Stack not reset correctly when have structure returned from function array
We have C compilers version 4.03 and was wondering if any compiler versions after this has this problem.
We have a function array set up to point to functions that return a structure. We have found that the stack is not cleaned up after returning from a function on this array.
The code would be something like this:
typedef struct
int value;
boolean status;
} struct_Results;
typedef struct_Results (*funcptr)(void);
const funcptr functarray[] =
GetFirstValue,
GetSecondValue,
GetThirdValue,
GetFourthValue
Then in the function:
int loop;
struct_Results results[4];
for ( loop = 0; loop < 4; loop++ )
results[loop] = functarray[loop];
The stack is off coming back from any one of these calls and the offset is times 4 since this function array is called 4 times.
Has anyone else experienced this problem?
Thanks,
Rick Brown
