I'm using the µ-Vision2 eval.-software and write in assembler. How can I simulate an input text using the serial interface of the controller. While debugging it's not possible to write a text into the serial window. Thanks for your help
Hmmm. It works just fine for me. I type in the serial window and the text I type is received and put into SBUF. What are you doing that doesn't work? Jon
