ISD51 connect error
I have isd51.dll ver 2.34.
I would like to use an ISD with TI TUSB3210 processor (like standard 8052 derivate).
And I've got an Error message from
ISD51 Monitor Error:
'There was no reply from the target system!'
I correctly set baudrate to 9600, tested both in simulator and hyperterminal as well described in ISD51.htm file. The function with 'A'character and output character work perfectlly. So I go back to simulator and try send HEX 0xA5 by sin=0xA5 command in simulator - it display 0xF7 followed by 6 hex values. => It seems that all work OK.
But when I try it in Hyperterminal it does'not work. So I think that when Debugger send initial command - no response from 8052 by UART.
Where should be an error ?
Radim
