C251 memory pointer problem
Is this a valid construct in you Keil C-251 compiler?
unsigned char data buf[20];
typedef struct {
int i;
int j;
} TEST_T;
#define GetStruct() (*(TEST_T *)&buf[2])
void Test(void) {
GetStruct().i = 3;
Notice that buf is in the data area and I'm type casting it to a TEST_T struct in the default memory area (which is in far). V3.53 of the compiler compiles buggy code when similar scheme is used. If I change the buf memory area to "near", or if I change the macro to
#define GetStruct() (*(TEST_T data *)&buf[2])
or
#define GetStruct() (*(TEST_T *)(unsigned char *)&buf[2])
then it compiles good code. Question is, was there something fundamentaly wrong with what I did in the macro?
Andy
